Much as the title really. I am confused as this has happened a couple of times recently. The blower fan will suddenly cut out when on anything but speed 4. When I turn it to 0 a few times, it will work fine again. Setting 4 works fine - every time. This does not sound like the resistor to me as it is intermittent. I did read some other threads saying that the plugs could be at fault and that the earth pin melts the connector. But not really too much to go on. Is this the plug on the motor, or the resistor? I will be taking it all apart as soon as I can, but wanted to see if anyone could shed a more definitive light on what this could be. The pollen filter is new, and the fan is free from any sort of build up, and generally works very well indeed. Bit of a head scratcher. I don't want to head in the wrong direction if I can help it, and just start removing everything if I can help it.
Cheers for any help guys
K
