Hi again folks!
I'm posting this on behalf of my brother as he's been having issues with his 09 connect. It keeps going into limp mode. It seems to be happening every so often and then it doesn't happen for a while but then it'll do it again when you least expect it.
He's had 3 injectors replaced already. The fuel filter was changed less than a year ago too. The revs don't go by 3k and I'm sure he has a power loss. Usually if he turns the engine off and on a few times then it'll reset and work but this time it just isn't going away. I've told him to try disconnect the battery for a while to see if it'll get it working again for now but the problem needs sorted properly!
So here's the codes he's got when scanning the van. It said something to do with the clutch sensor too but he's tried wiggling that around also with no luck.
Any help is much appreciated. I'll post more info from him when I can!
