Ford Connect 1.8tdci
Postby Doniix » Fri Apr 29, 2022 11:43 pm
Hey
I've recently bought a 2009 transit which needs a ecu replacement, the old one was sent of to be remapped and went missing
So I found a ecu in a scrap yard from the same model though it's from an 06
Will it work with or is something changes between those years
Can I just remap it with a vcm with ford Ids or do I need a newer ecu?
Doniix
Re: Ford Connect 1.8tdci
Postby metalworker0 » Sat May 14, 2022 2:02 pm
i reckon it would be different if it was from a tddi, rather than a tdci - that's all i can tell you .
Postby blue estate » Sun May 15, 2022 2:52 pm
06 will be no good as it’s a Delphi system , you need an 07 on Siemens system one
72plt MG 5 ev estate Battery car
blue estate
