Hi all, looking for some help , on odd occasions over the last 6 months the battery warning light comes on while driving, if you stop then turn her off then on it goes out . So I brought a new patch loom , but never got round to fitting it , then when I went over my dads yesterday the van seemed to cut out but the engine was still running and some of the dash warning lights lights flashed , only one I noticed was the glow plug light . Turned her off then on and she ran fine but it did happen again and at various points in my journey but there was no pattern to it .
My first thoughts were the alternator but from past experience you can never tend to drive very far before the car stops totally, so thought first stop replace the short loom from the alternator, but as others have found mine was one long loom , so cut about 150mm of the end and crimped some new terminals on took it for a 20 mile drive and it seems okay . What’s everyone’s thoughts ? Is the alternator on the way out ?
Which brings me to my next question, here’s some pics of my alternator,
I’ve never seen this type before, is it a standard one or air con ? Even though mine doesn’t have aircon, I have found the front end part with the free wheel clutch , which I’ll buy but can only find alternators with the pulley attached or the air con type . Any help and advice would be much appreciated.
Cheers Ian
