Hello,
I have a 2012 Ford transit connect with 170,000 miles on it. I put a new transmission in about 2000 miles ago. I am getting an oil light that blinks on. When it does the car throws codes saying bad shift solenoids. I replaced the engine oil and made sure it was full. I put in a new oil pressure switch. I cleaned up the conector of the pressure switch and cleaned up the battery terminals just in case it wasn’t making a good connection. I’m still getting the oil pressure light coming on randomly. When it does the service wrench light comes on as a well as the check engine light. When I read the codes I get P0750 (shift solenoid A), P0755 (shift solenoid B), P0760 (shift solenoid C), P0765 (shift solenoid D), P0770 (shift solenoid D). With the new transmissionI don’t believe these are all bad. How and why are these coming on when the engine oil light comes on? Has anyone else had or seen this problem? Any insight would be appreciated. Thanks
