Hi Gang, I hope you are all coping in this heat, My friend recently bought the above van & the clutch slave decided to fail, we took it to a locally recommended garage where they commenced to change the whole clutch assy including DMF, I believe LUK from Euro car parts, they noted the Crank sensor had been secured in place using silicone, they rightly recommended changing this including the mounting bracket, the sensor came from Euro & the bracket was located on eBay, now the van cranks but will not start.
Items swaped to try & prove point
DMF compared with original
DMF swapped again
2 x Crank sensors from Euro
1 x Crank sensor from Ford
Does any one have experience of this problem or thoughts on fault/problem, does anyone have any thoughts on the eBay provided crank sensor mount, is there any setting up measurements for the crank sensor & has anyone ever come across a siliconed Sensor?
