MinorMatt wrote:send me your VIN and I will see what I can do
Chug wrote:you only need to open it briefly until diesel dribbles out, too long and you will empty the filter and may draw air into the pump when you try and start, and I think condensation in winter was more of a problem years ago with metal tanks than with modern plastic tanks.
metalworker0 wrote:Well, looks to me, there will not be a large amount of space in there to hold water ..the drain must be for emergencies when Youd drain several times over a period of minutes to get rid of it.
all the best...mark
ned wrote:Is your connect a tddi or a tdci?
I don’t bother draining water from my fuel filter I just change the filter every 6k miles.
