by pyehelen » Wed Nov 16, 2022 11:49 pm
Hoping someone might be able to help. My ABS pump has gone in my 2016 mk2 connect and it can't be refurbished as has completely seized. The part numbers are GV61-2C405-AE and GV61-2C219-BB. Ford are quoting me 1500 for a new one and as I want to change the van in a few months was looking for a refurbished or used one. I've searched everywhere for these part numbers and have only found a match of the pump only but the seller isn't responding to my question on whether it will work with my control unit. I have found a close match where it ends AF and BC respectively but I'm not sure if this will work? Is there a way to find what part would be compatible and I'm also assuming it will need to go to Ford to be programmed? I've attached photos of the one that has been removed from the van. Thanks Helen
