Hi
I'm a complete novice trying to swap a transit connect starter motor. First of all I'm having problems removing the wiring to the solenoid. Finding it really difficult to access the 13mm nut because of the location of the alternator. Also can't remove the starter motor with the cabling attached because the alternator stops me moving starter motor back enough to get it out. Any help would be much appreciated.
Cliff
