Hi! I believe my fuse for low beam on driver side is blown. High beam is fine; low beams and left turn signal both not working even with new bulbs. I definitely did that correctly, the other side I changed the bulbs working fine.
For 2018 Transit Connect:
1) how do I access the fuse box under glove compartment? (Assuming this is the fuse box I need and not the luggage compartment or engine compartment)
2) WHICH FUSE IS THE ONE TO CHECK/REPLACE? Owners manual only lists the fuse for high beams, can’t find anything about which fuse for low beams, driver side and left turn signal.
Help! Supposed to leave tomorrow morning for long trip home to Thanksgiving and need all lights and turn signal!
Thank you!!!!
Denise
