Edit: I moved this post to "general" since it's not connect specific.
So in my MK1 connect, my inner wheel is grinding against my brake calipers when breaking hard or turning extremely, which would lead me to suspect the bearings are bad but I've got the hub off and the bearings feel smooth as butter.
I've replaced the drive shaft, the drop links, the ball joint and the track rod end.
The only other culprits are brake pads - they look okay but are worn down to 1/2" on the back, but about 1/4" on the front.
Other than that, the track rod end might have put the alignment off, but I'm not sure if that would make inner wheel scrape against the caliper.
It's it possible my bearings are bad despite being perfectly smooth spinning when the wheel is off?
