'17 Connect Limited SWB.
I've noticed an odd noise when pulling away sometimes, i can hear it for just a second then it goes away. It's hard to describe but it sounds like the noise you get when you drag a wooden dining chair across a tiled floor, you'll either know what that sounds like or you won't, it's definitely a distinct type of noise.
I've tried holding the handbrake and loading the clutch and it doesn't seem to do it then but I can't rule that out completely because the noise is so intermittent that I can't be sure. If I listen really hard while driving there's a slight possibility I can hear a wheel bearing whirring sounds but I may be imagining that, I've never heard a wheel bearing make that weird sound anyway and also I can't feel any play in the wheels if I shake them by hand.
Currently it's too intermittent for me to be able to replicate so I'm stumped currently. All I'm fairly sure of is that it's coming from the front somewhere.
