hi all could someone point me in the right direction my timing belt snapped few weeks ago when that happen I opened up the rocker cover to find it had snapped 4no rocker arms knowing this I took the head off to get the vales off that had the snapped rocker arm and there ok so put it all back together with new rocker arm and belt kit.
been primping the diesel now for a long time with no luck my have air leaking somewhere will need to replace some fuel Lines (if I can find them online)
the problem I have is the camshaft could be 180 degrees out to the crank I did use the locking pins at the 3 points but as the belt snapped the cam can be locked off in two points so does anyone know another way of making sure that the cam in lined up right to the crank without using the locking pin in the camshaft if I can just get this right I can put my time back in the sorting the fuel problem out.
cheers
