LostinTransit wrote:*yawn* it's a shame none of you have treated me or my posted topics with respect or I would have helped you with this cause I removed the front flooring in order to access the dead peddle/foot rest..
Ripp wrote:LostinTransit wrote:*yawn* it's a shame none of you have treated me or my posted topics with respect or I would have helped you with this cause I removed the front flooring in order to access the dead peddle/foot rest..
I tried PMing you a while back but your profile is set to not accept PMs. Would you be kind enough to link to where you explain pulling the floor up?
Nordic Blue wrote:Ripp wrote:LostinTransit wrote:*yawn* it's a shame none of you have treated me or my posted topics with respect or I would have helped you with this cause I removed the front flooring in order to access the dead peddle/foot rest..
If you click on his username on his post you should be able to search through what he has posted.
metalworker0 wrote:Any good ..possible cause of water leak
https://www.youtube.com/watch?v=lSl3IBZmTFY&t=49s
all the best..mark
metalworker0 wrote:This is the floor covering for mk1
https://razborka.ua/files/images/shop/big/mb297196.jpg
if similar ..looks like you'll be taking both seats out ...as its all one piece
metalworker0 wrote:BTW , have you done the cooling system pressure test, as i advised...this may save you a lot of trouble ..as pressurerising to 15 psi ..will turn small leak into drip and reveal all. if the leak is from heater matrix or associated hoses.
metalworker0 wrote:Found pics of mk2
very confusing as everyone is displaying fitted custom separate piece mat sets..so this was hard to find>
https://www.ebay.co.uk/itm/Ford-Transit ... 5303592383?
press on "see original listing"
and here you can see ..as well as the seats the bits of trim you have to remove to get at it
https://www.ebay.co.uk/itm/Transit-Conn ... 4968283171?
again press on "see original listing"
akll the best..mark
