Low Idle Issue - 2014 TC 2.5L
Postby dsm600rr » Wed Sep 27, 2023 5:32 pm
Hello all,
New member here - 1st post. I am looking for some help tracking down a low idle issue.
When the vehicle is cold and started up, the idle is fine, until it warms up. Once it is warmed up, I am seeing approx: 650-730. I do not know what it should be at, however it feels low.
When I turn on the AC, the idle feels perfect. I am seeing approx: 770-790
Lastly, when I stop in somewhere quick, and go to start the vehicle while it is still warm, no AC - the idle with dip quite low and try to rebound, and then it settles at the 650-730RPM range which feels too low.
https://youtube.com/shorts/kKCVmufHf2E
The vehicle is not showing any codes:
The Vehicle Recently had replaced, with OEM:
- Spark Plugs with OEM MotorCraft SP-530-X
- Ignition Coils with OEM MotorCraft DG-522
- Air Filter
- I cleaned the MAF in some rubbing alcohol - no change
I appreciate any suggestions.
Thank you!
dsm600rr
Re: Low Idle Issue - 2014 TC 2.5L
Postby dsm600rr » Wed Sep 27, 2023 6:38 pm
dsm600rr
Postby knobby1 » Wed Sep 27, 2023 8:14 pm
2014 2.5L..??
You've got me confused....there's no such animal as a 2.5L petrol engine in a 2014 Transit.
Postby dsm600rr » Thu Sep 28, 2023 1:39 am
knobby1 wrote:2014 2.5L..??
https://photos.app.goo.gl/sLnBWSDhK1SWiskv9
dsm600rr
Postby knobby1 » Thu Sep 28, 2023 2:47 am
Ah...so it's not actually a proper Transit...it's a Connect.
Proper Mk7 Transits only had a 2.3L petrol, 2.2 & 2.4L diesels.
You should go to the "Connect" section of the forum...:
viewforum.php?f=54
Postby Altransit » Thu Sep 28, 2023 9:18 am
knobby1 wrote:You should go to the "Connect" section of the forum...:
viewforum.php?f=54
Indeed, I'll move it, to save confusion :)
