Started, left side (the better side).
While not a complete disaster, in fact mostly expected, there is plenty of work to be done.
The middle sill needs to be replaced and at least the rear part of the inner sill too.
I'll have to cut it out anyway to replace the middle sill.
But I'd like to maintain as much original steel as possible, as I just lack the equipment and money to do bigger repairs. So if the condition of the steel is passable, it'll get welded back.
Ideally I'd replace any and all pieces of contaminated metal. But if it has just some surface rust, It'll have to do. It's the best I can do right now.
I'll just have to get the rust off and repaint the metal. Of course, if it has more than surface rust, it's going to get replaced. I'll just have to make do with the rest.
Hopefully I'll be able to see with a bore camera how high the rusting goes.The higher it goes, the higher I need to make my cuts and the harder it becomes to protect the metal from the other side, once welds are laid on.
Rear:
Front:
Middle sill.
For the most part, it's just surface rust. But it will still have to be replaced.
The right side is much much worse with some really shoddy snot weld repairs done by the previous owner just to pass inspection.
However, I reckon I'll have to ultimately do pretty much the same amount of work and repairs on both sides.
It's midsummer celebrations time now.
