Ford transit connect 1.5 2018 P0001 NON STARTER ?
Postby Rob-transit » Tue Mar 05, 2024 5:53 pm
Van was running when engine changed and now with the new secondhand engine its a non starter and the code P0001 comes up as open circuit fuel control valve . No power to fuel control valve and no power to injectors . Pump is not building up to desired pressure . Any ideas ??
Rob-transit
Re: Ford transit connect 1.5 2018 P0001 NON STARTER ?
Postby metalworker0 » Tue Mar 05, 2024 10:41 pm
I cant understand your post
car was running when engine changed ?
does that mean:
1. it was running before engine change.then you changed the engine ..and its not running now
or does it mean:
2..you changed the engine ..then it was running ..now its not.
if 1. ..then the new engines injectors and maybe other things will have to be coded to the ecu
if 2 ..no idea ..
suggest putting this search line into youtube ..and watching all the videos
"ford 1.5 p1001 code"
sorry but i know less than you about this engine, but that is where i would search for the answer. and if i didn't answer this post ..the way its going here , there is a chance, no one else would ..so at least you got a reply
Postby Rob-transit » Wed Mar 06, 2024 10:01 am
Hi its not my van there was a problem with the head and the engine was smoking badly. I did not change the engine i am trying to help the guy get his van back on the road
Rob-transit
