Wiper arm spring rubbing on windscreen
Postby iain walters » Wed Mar 20, 2024 1:46 pm
Hi
I recently had the windscreen replaced on my ford transit connect, And a couple of days have passed now and we have had some rain, i noticed a scraping noise when my wipers were on so i stopped to take a look. the driver side spring on the wiper arm is rubbing along the screen when in operation.
Can the nut be overtightened holding the wiper arm? should it be torqued to a certain value?
The nut itself is not loose which was my first thought thinking that the arm hadn't been secured properly.
iain walters
Re: Wiper arm spring rubbing on windscreen
Postby metalworker0 » Wed Mar 20, 2024 2:58 pm
Can only give you an answer for mk1 ..as that's all i have to check
There are only three possible ways that the spring can drag on a mk1
1 .Arm is now bent after windscreeen fitter damaged it
2. Rivet that holds hinged part together broken
3. Spring has broken
