Replace turbo Connect 2008
Postby Fordaren » Wed Mar 20, 2024 2:29 pm
Hi. Anyone know how to replace turbo in 1,8 tdci. (Connect 2008)
Fordaren
Re: Replace turbo Connect 2008
Postby TorhanPiper » Mon Apr 01, 2024 11:18 am
Replacing a turbocharger can be a complex job, especially for a beginner. While there are online resources that might offer a guide, here's a breakdown to consider for your 2008 Transit Connect 1.8 TDC:
Safety First: TDI engines involve high pressure and potential hazards. Unless you're very comfortable working on cars, it might be safer to take it to a qualified mechanic.
Expertise Needed: Replacing a turbo involves knowledge of the engine system, removing and reinstalling various components, and proper torquing procedures.
Special Tools: You might need specific tools to access the turbo and complete the job correctly.
Alternatives to Consider:
Mechanic Quote: Getting a quote from a mechanic can help you weigh the cost of professional repair versus the risks of a DIY attempt.
Online Resources: If you're still determined to DIY, be sure to find a reputable guide specific to the 2008 Transit Connect 1.8 TDC turbo replacement. Look for instructions with detailed steps and pictures. Here are some tips for searching online guides:
Search for "2008 Transit Connect 1.8 TDC turbo replacement guide"
Look for guides on websites known for car repair tutorials (avoid random forums)
Read reviews or comments on the guide to see if others found it helpful
TorhanPiper
Postby metalworker0 » Mon Apr 01, 2024 12:43 pm
I have not done the job ..so no advice ..its stuffed right down the back of engine, crammed into a very tight space. 2008 - so bolts will be rusted solid, studs may snap , nuts will round.
That would be my first thoughts . if you cant cope with or are not prepared for something like that happening - then do not attempt.
oh - don't use 12 sided sockets on bolts like that ...hex only
Postby Altransit » Mon Apr 01, 2024 11:21 pm
As above, space around the turbo is very sparse. It can be done using smaller hand tools, ring and open ended spanners are useful for the really awkward ones, but you still need nimble fingers and a lot of patience.
A small cold chisel, and a hammer can be used carefully on the edge of the nut flats to "shock" any nuts that are tight :idea: Oh, and plenty of anti-seize fluid
Postby megaross » Fri May 31, 2024 10:15 pm
My experience of stuff like this as a classic car owner for years before I gave in and bought anything modern. If you have choice just take it off the road, soak all the fasteners multiple times with plusgas over a few days then get a blowtorch and heat and cool everything you can.
If you've got patience you can make fasteners that look like they've come off the titanic spin free. I'm talking nuts that were 13mm and now need an 8mm socket hammered on.
But if you do snap anything loosen the engine mounts, support on a jack and then scissor jack the engine forward and you can usually get an extendo bit holder in to drill and helicoil.
megaross
