Hi
Looking for the Low pressure port on a MK2 2019 - to charge the air con. I've found a port that is just in front of the washing bottle, under a plastic flap. I also found a port that is right at the back of the engine - difficult to get at, and so, would be really difficult to get a recharging nozzle on there. The diameter of the first port is approx 14 mm (measured)- looking at the second port it looks the same diameter (i cant get in there to measure it).
If these are the same diameter, I would think these are both lowside (?) But to be sure I need to find the High side port ( highside port has a larger diameter).
Of course someone could tell me that You charge from the first port mentioned as They have sucessfully charged the air con system from here.
Had a MK1 for 17years (loved it !) and just bought this (MK2), but trying to find info is difficult - they don't even do the Haynes manual anymore - and the 'autofix' are rubbish (allegedly)
In addition does any know if the 'easymanuals' download only - are any good ? Or a place to buy a decent workshop manual ?
Thanks in advance
