Steering assist problem
Postby filesy » Tue May 07, 2024 3:29 pm
Hi, the steering has gone on my 2018 connect, I checked all fuses and all ok, I took the plunge and bought a second hand rack, fitted it and the problem is the same, any ideas most welcome please ??? TIA
filesy
Re: Steering assist problem
Postby metalworker0 » Tue May 07, 2024 7:18 pm
Sorry I've no idea ..it's a steering rack with an electric motor on it.
in case anyone wants to come here and guess.
But, i did find something about a software upgrade ..the upgrade has a part number and its: 1939539
Mandatory Software Update To Calibration File CV6T-14C218-AJ REF. A12712876" For Part CV6C 3D070 ME - Transit (42752S)
That itself ..tells me to get this thing working, you are going to be plugging in a scanner,, or you are getting no where
You need Forscan (this is free) downloaded to a laptop or mobile and the interface cable is called an ELM 327 to plug it into the OBD2 port
to learn how to use this ..join the forscan forum
https://forscan.org/forum/
Even with that knowledge you may find out that its a fault with the BCM - body control module ..or a fault with something like parking assist , even wheel alignment and a pile of sensors can cause it to stop working.
forscan will tell you the fault code ..and reason its failed ..if not you put the code into google to find the answers .
Postby filesy » Fri Oct 04, 2024 4:49 pm
REPLACED THE STEERING RACK {USED} and new battery and still not resolved, no codes to be read ! any help gratefully received.
Dash says electrical assist needs a service !
filesy
Postby metalworker0 » Fri Oct 04, 2024 6:04 pm
Did it turn out to be an electric steering rack ..did you get forscan
Note on most modern transits the diagnostic system groups stuff together ..it may say it has steering assist has a problem because it perhaps needs the ABS system to work, the abs system doubles in with traction control and even a tyre low on pressure , or wrong size tyres fitted, or bad wheel sensor can put the system into disarray.
did you read my answer ..did you take note of what i said .
forscan has many features that will help you out .
other things ..the new rack has to be learned in, if its electric, there will be part of forscan where you can do this ...you need to know how to set things up to tell the body control module that everything is correct ..sorry i don't know how to do this.
and probably no one here knows either - try youtube
The steering wheel ...it has a sensor in the steering wheel that tells the body control module what angle the steering is at. there are sensors on the rack that say where the wheels are pointing...all has to check out.
forscan does not now use ELM327 interface cable, as mentioned 6 months back.
Postby metalworker0 » Mon Oct 14, 2024 9:28 pm
this is the clock spring centralisation procedure for a mk8 transit..sorry no connect ..we / i dont have the manual
hope this info helps you somewhat
