Mk1 stiffer throttle pedal?
Postby 08SWB-connectOwner » Thu Jun 13, 2024 5:54 pm
Hello again.
I drive my TC almost 200km each work day and because of the throttle pedal being so light, I can't 'rest' my foot on the pedal and have to hold it in a slight tension.
I actually have now developed tendonitis because of this.
So I thought, seeing as I now have two weeks of sick leave, I might as well put that time to use and fix the issue.
So my question is:
Is there a sensible way to stiffen up the pedal a bit, without resorting to some rube goldberg-esque doohickery?
Thanks.
08SWB-connectOwner
Re: Mk1 stiffer throttle pedal?
Postby metalworker0 » Thu Jun 13, 2024 9:18 pm
i don't know as I've never touched mine
here is a picture of it ..so you know what to expect
not shown are springs if it has any
not shown bushings .
it could be something to do with them ..as there is no throttle cable ..because its fly by wire.
https://www.catcar.info/ford/?lang=en&l ... NysxMzM%3D
Postby 08SWB-connectOwner » Thu Jun 13, 2024 10:58 pm
As far as I understand them, fly by wire pedals most often have a clock spring in them.
I guess I could add some winds to it, if the pedal can be disassembled to such extent, but I guess I'm looking for a known solution.
Something someone else has done and found functional and safe.
08SWB-connectOwner
Postby dumper » Sat Jun 15, 2024 12:03 am
Try another van if you can just in case yours is weak
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
