Highest Capacity Connect Battery?
Postby Cridders » Thu Jul 04, 2024 9:14 am
Hi, I need a new battery for my 66 plate Ford Transit Connect lwb.
I've had a look on the part finder on Ebay, put the reg in, and it brings up options which when i double check are not compatible for my van. I've seen some with a higher capacity (85ah) which i'd like as i'm always going flat after a full day on a job, opening and locking the doors all day, but can't seem to find one that will definitely fit. When i look elsewhere the best i can find is 70ah.
Can anyone recommend the highest capacity compatible batter for my van please?
Thankyou
Cridders
Re: Highest Capacity Connect Battery?
Postby metalworker0 » Thu Jul 04, 2024 1:58 pm
its easier to phone up Tayna batteries they will have answer to your questions
01745 823399
I know you just cant pick any battery
Terminals have to be on the right way around
Dimensions have to be right...too big and it will not fit in the battery tray, too small and it will not clamp down.
As you can see lots of codes , lots of choices ..so you get to make your choice ..not me
https://www.tayna.co.uk/Ford-Transit-Co ... 18578.html
NOTE: all battery codes have changed lately with all this stop/start stuff
Years ago, you would have put into ebay "096 battery" 85AH and you'd get the right one - not any more
Postby Cridders » Sat Jul 06, 2024 12:31 pm
Thanks for that, that webiste has loads of options, cheers
Cridders
