Diesel leakage
Diesel leakage
Postby UK-Connect 2019 » Fri Jul 05, 2024 12:54 pm
Hi all, novice here. I have recently brought a Mk2 2019 L2 Transit Connect, all good except I have found a diesel leak, under the bonnet. The leak is coming from the rear pipe on this round thing in the photo. Can anyone namet his part and let me know if it is an easy fix please. Many Thanks.
UK-Connect 2019
Re: Diesel leakage
Postby metalworker0 » Fri Jul 05, 2024 2:48 pm
found on site here -- https://www.catcar.info/ford/?lang=en&l ... IyNzUrMTMz
if your van is
1.6L EcoBoost SCTi
which i think is a petrol engine
...so my results may be wrong :oops: cant find any other thing looking like it anywhere.
if 1.6L EcoBoost SCT - appears to have 2 parts numbers
5323737
5327991 alternative part number
no idea what it is or what it does, looks like - can only be purchased as a whole pipe
Cant find any ..not on ebay ..not on google
You are stuck with buying it directly from a ford dealer... or work out how to repair it bypass it etc --- that's if you can figure out how to do that safely.
here's the section covering fuel lines if you want to wade through it .
Re: Diesel leakage
Postby UK-Connect 2019 » Fri Jul 05, 2024 3:52 pm
Hi, it's the 1.5 diesel engine.
UK-Connect 2019
Re: Diesel leakage
Postby metalworker0 » Fri Jul 05, 2024 8:51 pm
Ok found it - it was just a green squiggly blur in the parts diagram so was hard to find
https://www.catcar.info/ford/?lang=en&l ... NCsxMzM%3D
has two part numbers
search ebay for these two- using words below
ford 2028155
4 results - all very expensive
ford 1872194
- has two genuine brand new ford ones in the search for £40.24 and 2 used
one of those is yours ..which i don't know...perhaps they are identical with just two part numbers! the two genuine ford ones have no pictures!
sorry about not giving direct links to ebay ..the forum breaks the long ebay links
