Hi Gents,
I'm struggling with a crank no start situation on my 2011 Connect 1.8tdci - high pressure pump is not sending fuel to the injectors.
I thought this was maybe down to air in the system as I had my engine apart to do other stuff, but after much pumping and bleeding still no joy.
I came across a video on Youtube ( it was in Polish unfortunately!) and the guy in the video was replacing the fuel pump on his 1.8 tdci. He had the replacement second hand pump on the bench, and when he rotated the pulley by hand, some fuel spat out of the output fuel line, indicating that there was internal pressure generated by the rotation of the pump.
So today I removed the fuel line from my pump which runs from the pump to the spider, then I turned the engine over via a ratchet on the crank pulley - no fuel spat out like it did in the video I saw. I then put my finger across the fuel pump outlet and turned the engine over again by hand, and I could not feel the faintest bit of pressure, not a gnats breath.
From this should I assume that my pump is dead, or are there any other simple tests I can do ?
It's not the cheapest of parts to buy, so don't want to splash out unless I have to!
Thanks gents, grateful for any advice as always.
