What voltage at high pressure pump connectors?
Postby pierresmith » Wed Jul 31, 2024 4:18 pm
Hi Gents,
I wondered if anyone could tell me what voltage I should have at the pins of the connectors on my high pressure fuel pump?
( 2011 Transit Connect 1.8tdci )
There are two connectors, one on the pressure regulator, and one on the fuel metering valve.
I ask because I wanted to bench test my pressure regulator. On Youtube they show two tests to carry out, a resistance test across the pins, and then a voltage test in which you should see the solenoid activate. On the solenoid activation test they were hooking up the pressure regulator to the positive and negative of a 12v battery, which makes sense. But when I tested the voltage at the pins of my 2 pin connector, I didn't have 12v and ground, I had 12v and 5v.
I tried hooking the regulator up to a battery but I couldn't get anything to activate/fire.
Maybe I'm misunderstanding something, just thought I would ask in case someone knows!
Thanks.
pierresmith
Re: What voltage at high pressure pump connectors?
Postby metalworker0 » Thu Aug 01, 2024 10:55 pm
I'm sure it will be in the BEMM ..Body and Equipment Mounting Manual, all the test stuff ,,voltages and procedures are in it ... this a supplement to the main manual that you should read first
sadly no ones shared it
I've looked and looked
if you want to look, try covering areas that i haven't
like the 1.8 tdci Focus BEMM manual
also try = GALAXY, MONDEO, C-MAX, S-MAX, 1.8 TDCi of the same period in time
all the best .mark
Postby pierresmith » Fri Aug 02, 2024 8:27 pm
Thanks Mark, I'll do some digging. I wish one of my mates had a Connect so I could pull off a couple of plugs then test and compare!
I think ( and I stress think ) that both of the two pin connections on the pump should maybe have a 12v pin and a 5v reference pin.
I have this when I test the pins with the ignition on, but interestingly when I check them with ignition off one of the pins gives a ground signal, which tells me I might have a short somewhere.
Oh well, I'll figure it out eventually I guess.
Cheers
pierresmith
