ford transit connect 2014 diesel Idle missfire
Postby Aftab » Mon Aug 19, 2024 11:20 pm
Hello all
I Brought this van month ago when i start cold engine Shake and missfire alot also smoked after 10 mint its stop engine shaking but still missfire i cheaked injector seems ok the van drive fine no issues when Draving only missfire When the van is in idle mode i changed diesel filter fully serviced changed one injectors
Aftab
Re: ford transit connect 2014 diesel Idle missfire
Postby metalworker0 » Tue Aug 20, 2024 1:49 pm
You must post derails like engine size etc
I'm assuming its a 1.6
and because EGR ..is problematic in all vehicles ..they must be serviced and cleaned out of carbon at regular intervals .
Do that, take it apart , clean it ,, make sure Moving parts are free and work
if you have the same problem after this . then you must plug in a code reader ..to find out what is going on.
Postby Aftab » Tue Aug 20, 2024 2:04 pm
Hello
Thanks for your reply my Van is 2014 diesel 1.6
I put obd Reader no Fault code Found
Aftab
