Wet belt 2011 connect
Postby painter4 » Sun Aug 25, 2024 2:29 pm
Hi , I have 2011 connect I presume it does have the wet belt from what I have been reading on this forum ,the van has only done 48k but it is over 10 yrs old , should the belt be done ASAP? thanks for any help .
painter4
Re: Wet belt 2011 connect
Postby metalworker0 » Sun Aug 25, 2024 3:06 pm
Yes it should be done, even if you find no damage, time is not on your side - a service history with oil changes done at 6000 miles would make me rest easier ..but if you don't know that, then presume that its been done at fords 15,000 miles which will not help a wet belts longevity.
The top "dry belt" should also be changed.
some say here to convert to chain, whilst you are at it-- but that is down to your resources and mechanical knowledge.
Postby painter4 » Sun Aug 25, 2024 4:53 pm
Thank for the reply , for peace of mind think will get both belts done , although I do have full police history as it was surveillance vehicle, it shows oil and filter changes at 6k intervals ... but as you mentioned age . Thanks
painter4
Postby metalworker0 » Tue Aug 27, 2024 1:26 pm
Yeah - if when its taken off and if found to be deteriorated, put pictures on here to show its condition.
will serve as a warning to all or give people a general idea what they can or cannot get away with.
Postby painter4 » Tue Aug 27, 2024 1:43 pm
Thanks ... just been to ford as im not sure to trust a garage with no experience of them , anyhow they have it down as a 5.5
hr job plus parts , at £95 per hour plus vat
.... so just waiting for a full estimate to have both belts and water pump done ..
I will make sure I'm sitting down when they tell me though ..
painter4
Postby painter4 » Thu Oct 31, 2024 7:17 pm
The full estimate from ford , for wetbelt and waterpump and cambelt is £2300 Inc vat ...
So I've found a TDCI specialist that will do it for under 1k ... wetbelt to chain conversion
Mine is 2011 and defo left the factory with a wetbelt ...
painter4
Postby MrTango » Tue Jan 21, 2025 1:16 pm
Hi Painter4,
You say that you have had the conversion done. Can you provide details for the company that did the job?
Was this company recommended to you etc?
MrTango
