2014 transit connect
Postby pauliil1948 » Tue Sep 24, 2024 9:16 pm
Hi guys, I changed my fuel filter today and silly me thought it would self prime so it started up for about 30 seconds then died now my battery is flat with turning it over, so will stick another battery on and get back to it tomorrow, so advise needed on correct procedure , and I am not sure which is the fuel in and fuel out on the Any help pics or advice much appreciated
pauliil1948
Re: 2014 transit connect
Postby metalworker0 » Tue Sep 24, 2024 11:02 pm
You are supposed to pre fill the filter ...and once done, engine starter spray may get it going fast enough to prime the system.
fuel pipes - Don't know ..as you don't say what engines in it ..anyway its not a 1.8, so therefor leave it to someone else to answer.
all the best..mark
Postby pauliil1948 » Wed Sep 25, 2024 7:57 am
pauliil1948 wrote:Hi guys, I changed my fuel filter today and silly me thought it would self prime so it started up for about 30 seconds then died now my battery is flat with turning it over, so will stick another battery on and get back to it tomorrow, so advise needed on correct procedure , and I am not sure which is the fuel in and fuel out on the Any help pics or advice much appreciated
sorry guys it’s a 1500 diesel not sure what engine it is engine cover missing
pauliil1948
