Hi all, i am having problems finding a fault with the near side, side lights.
There seems to be no power there, and continuity shows its going to ground, from the rear to the passenger footwell, that's the orange and white wire. all fuse meter ok, but i will check again
i haven't metered the front yet as the fault used to just be on the rear light and i thought that might stop the front working.
I have checked bulbs and replaced, i have checked for bad earth, i have removed lining and checked for screws hitting cable ect, i cant figure out how to the remove the pin from the rear light cluster block to check it, but surly it shouldn't go to ground.
Sorry for the long post, but am i missing something, thanks for any help.
