Used to run an 08 transit connect, 250,000 miles never missed a beat, so when I needed another LWN+B, Hi Roof, a 2013 was the ideal choice. 178k miles, mint condition, well looked after and serviced.
Been stood for nearly two years, but now starts and runs on the button.
Bloody thing over heats, so I've followed the following procedure:
1. Complete flush using hose pipe pressure, was full of rusty water, cleaned out, drained and flushed.
2. Air pressure blown down through the spanny tank feeds (2 pipes) to ensure clean.
2. New water pump (metal impeller, rad thermostat and new abs casing.
3. New radiator (was fitted before I bought the van)
4. Filled with just anti-freeze, pink and clean.
Car warms up, then goes to Hot, then drops back to normal, then hot again. Under marginal load.
Cab heater wont blow hot air.
Van up on ramps.
Popped each heater hose off so I could test for fluid, every joint had fresh anti-freeze, both flow and return through the heater matrix, through the egr cooler and the oil cooler at the back.
The thermo housing bubbled some air, then fluid.
The steel Y piece under the thermo housing that connects to the bottom of the rad and then a steel pipe that runs behind the block, anti-clockwise, all have fluid.
Topped the spanny tank up and noticed small bubbles so presumed maybe a head gasket, ran a sniff test for 15mins and remained blue. Blew through the trap to test the fluid and it immediately went yellow, so presume no co2.
There's no real pressure in the top radiator hose, gets hot and you can squeeze forcing fluid back in to the spanny tank.
Thought maybe the egr cooler was leaking (def flow of fluid through it) so i blanked it off both ends using egr blanking plates. (Cheaper than buying a new egr cooler). I also topped up the cooler pipes with anti-freeze to try and eliminate any air pockets (given thats a high point).
Cannot get the heater warming up, and it stop over heating.
Guessing my cab heater now wont heat up as the egr is blocked off, but guessing. Would hope heat is fed from more than just the cooler though.
Does anyone have an exploded diagram of the cooling system they could kindly share. Its doing my head in.
Vans not used much and runs a dream, apart from this annoying issue.
