by metalworker0 » Fri Nov 22, 2024 9:25 pm
google says
A "Transmission Limited Function" on a Ford vehicle's dashboard could be caused by a number of issues, including: Worn or damaged components, Low or contaminated transmission fluid, and Clutch failure.
Other reasons for transmission issues include:
Malfunctioning engine control module
Bad internal connections
Worn-out sensors
Faulty solenoids
Transmission overload, which can be caused by sudden acceleration, driving up steep hills, or driving with a full vehicle
If you own a Ford Powershift vehicle, you may experience problems with shuddering, slipping, or rough shifting. The clutches in these gearboxes can wear down faster than expected, causing them to fail. However, a well-maintained Powershift gearbox can last for several years and thousands of miles.
so start with the cheapest and easiest first
check fluid level, this could be especially relevant if you park on a slope ..its giving you and early warning
To check the transmission fluid level
to do that - refer to owners manual
- i did look, but too much conflicting stuff on google
