Hi all,
Recently bought a 2018 1.5 connect.
Previous owner had misplaced the security wheel nut key, and had snapped the head off one of the security wheel nuts trying to remove it.
So I managed to remove the 3 good security nuts with a lug removal tool.
The 4th snapped bolt (front axle) - there was no option other than to drill the stud out, which I did.
Got a replacement wheel stud, removed wheel, brake, disc.
No way to replace the stud without either
1. dismantling the hub (new bearing I guess?). Not a job I am prepared to do at home.
2. Grinding a nook out of the hub to create space to get the old stud out / new lug in. Not sure about this. Don’t want to critically weaken the hub for obvious reasons.
3. Giving up and running 4/5 nuts
4. Your advice here….
What should I do?
TIA
