Engine Service Now - 1.5 TDCI Duratorq
Postby surfrockuk » Sat Dec 07, 2024 8:05 pm
Hello, I've been lurking around here for a while but time for my 1st post!
My 2016 Tourneo Connect 1.5 TDCI Duratorq is showing Engine Service Now after 10 minutes driving and restricting power. I've replaced Oil, Oil Filter, Air filter, Fuel filter and reset the OBDII codes then this one came back:
Code: P06DD - Engine Oil Pressure Control Circuit Performance/Stuck Off
Checked the Oil pressure through Forscan and its reading 15psi/1bar with Key on, engine off. Looks like a faulty sensor but what do you guys think? Also, Where is the Sensor located on 1.5 TDCI Duratec?
I bought Haynes autofix but it has proved useless. :lol:
Thanks, Rob
surfrockuk
Re: Engine Service Now - 1.5 TDCI Duratorq
Postby metalworker0 » Sun Dec 08, 2024 1:14 pm
Think its near the bottom of the dipstick tube about 2 - 3 inches up screwed into the block
see here
https://i.ebayimg.com/images/g/pxwAAOSw ... l1600.webp
and here the red object part number 1866362
https://www.catcar.info/ford/?lang=en&l ... EzMw%3D%3D
genuine ford £64.99
https://www.ebay.co.uk/itm/393399949075?
others makes ebay
from £37.94
Postby surfrockuk » Sun Dec 08, 2024 2:52 pm
That's brilliant! Thanks Mark.
Nice little discount on ebay too :)
regards, Rob
surfrockuk
Postby MarkyC312 » Sat Dec 28, 2024 6:28 pm
Hi Guys,
just seen this post and this is my first post - i have a very similar problem, where by the Engine Service Light comes on, when going up hill. i have a fault code of PO66DD which indicates the oil pressure switch, however looking at the post the oil send sensor looks different the connection is black.
is there a oil pressure switch and a oil pressure sensor or are they the same thing.
my van is a 2016 1.5TDI transit connect on a 66 plate. when i type in to Euro parts, or any other part supplier and put the reg number in i get this, and for all the sausages in the world i cannot find this.
If it is not this one and it is the Black pressure sender sensor, is there a procedure to do this as i can just see it, but looks a nightmare to get too
Thanks Mark Clements
MarkyC312
