2022 Connect Starting Problem
Postby NKF » Thu Jan 02, 2025 11:51 am
Hi all,
I am new to this, so please bear with me.
I have a Transit Connect 2022 (Ireland) and it has run fine pretty much until now.
I has just been services at 61k km.
I went to use the van on Tuesday and started fine. Then all of a sudden, while still idling, the engine stopped. It came up on the dash, that it needed a manual restart. So I turned it over and it didn't fire. It sounded as if there was no compression.
I opened the bonnet and opened the oil filler and noticed that I could see the cam. I thought is it was a cam belt, damage was already done so asked my daughter try and start the van. I could see the cam turning as normal, but still no firing and sounding as if no compression.
My thought is that perhaps it is a blown fuse, but looking at the fuse information I cannot see a specific ignition fuse.
Has anyone experienced something like this in the past, any ideas what could be the problem.
Any help would be appreciated.
Thanks.
NKF
Re: 2022 Connect Starting Problem
Postby metalworker0 » Thu Jan 02, 2025 4:32 pm
in 2022 the connect had a number of options for engine size and fuel
please state this information or no answer will be given
all the best.markl
Postby NKF » Thu Jan 02, 2025 5:08 pm
Sorry,
It is the 1.5 Diesel. It is either the 100PS or 120PS engine.
Neil
NKF
Postby metalworker0 » Thu Jan 02, 2025 5:24 pm
OK. SAME ANSWER as this recent post
viewtopic.php?f=54&t=231162
cant really add to it.
all the best......mark
Postby NKF » Thu Jan 02, 2025 6:46 pm
Thanks Mark,
I had a look at that earlier and sent it to my mechanic.
Neil
NKF
Postby NKF » Fri Jan 03, 2025 6:39 pm
Okay, The engine is now running fine.
The van had not been started since the 20th December and I started it again on the 1st January, when the engine died.
My Ford dealer said that the earliest they could look at it would be into February, so could I get someone local to look at it.
My Mechanic came over today to check out the fault codes, there was nothing. Not sure exactly what he did but it came up with a message on my Ford app, Powetrain Malfunction / reduced power. Apparently it turned out to be the hydraulic tappets had lost oil and once the oil pressure build up by running it on the key it then fired up. It has been running for an hour or more on the drive and I have now taken it out for a run of 30km and everything seems to be running fine.
I thought I would share this as it had nothing to do with the timing being out as such, just that the valves were not operating properly.
I need to mention this to the Ford dealer and see is they have heard of anything similar.
Thanks for the comments and views.
Neil
NKF
Postby metalworker0 » Fri Jan 03, 2025 7:45 pm
Ok Thanks ..now filed my brain, as one of the possible answers, should someone have the same problem. after standing.
