2013 Connect - airbag light with U0401 Fault code
Postby willshill » Sun Jan 26, 2025 6:21 pm
Hi all.
My 2013 connect is showing a U0401 fault code and the airbag warning light. I by passed the connector under the drivers seat but the light returned. Then I replaced the battery (it was due) as I read that U0401 ECM communication failure can be caused by low voltage....no luck.
The airbag light resets after every start and appears to only come when I have a passenger.
I didn't think the 2013 model had a seat weight sensor. Or maybe it's a seatbelt sensor.
What would you suggest i try next?
Thanks in advance!
willshill
Re: 2013 Connect - airbag light with U0401 Fault code
Postby DanMK7uk » Sun Jan 26, 2025 6:56 pm
Disconnect battery for half hour. Reconnect. Sorry cant offer anything more specific.
DanMK7uk
Postby metalworker0 » Sun Jan 26, 2025 7:41 pm
Googling , this is, the most comprehensive answer i could find.
A "U0401" fault code on a Ford Transit indicates an issue with communication between different control modules in the vehicle, meaning it's receiving invalid data from one of them; to fix this, prioritize checking the wiring and connections between modules, inspecting for damaged wires, loose connectors, or poor ground connections, and then consider potential faults with the specific control module sending the faulty data; if the problem persists, professional diagnosis and repair may be necessary as it could involve complex electrical troubleshooting and potential module replacement.
Key steps to troubleshoot a U0401 code on a Transit:
Read the code details:
Use an OBD-II scanner to retrieve the exact U0401 code and any associated freeze frame data to understand the context of the fault.
Visual inspection:
Check for visible damage to wiring harnesses, connectors, and control modules.
Check for loose connections:
Inspect all connectors related to the CAN bus system, ensuring they are securely plugged in and not corroded.
Verify ground connections:
Check for clean and tight ground connections on all relevant control modules.
Test wiring continuity:
Use a multimeter to test the wiring between modules for continuity and resistance, ensuring no broken wires or high resistance connections.
Check CAN bus system:
If your diagnostic tools allow, monitor the CAN bus communication for errors or inconsistencies.
Potential faulty modules to check:
Powertrain Control Module (PCM): This is often the primary suspect for a U0401 code.
Body Control Module (BCM): May be involved depending on the specific vehicle system affected.
ABS control module: If the code is related to the ABS system
When to seek professional help:
If you lack the necessary diagnostic equipment or electrical expertise.
If the issue seems complex or involves multiple control modules.
If you've checked all basic connections and wiring, but the code persists.
Important points to remember:
Clear the code:
After making repairs, clear the fault code and test drive the vehicle to verify the issue is resolved.
Consult repair manuals:
Refer to your vehicle's specific repair manual for detailed wiring diagrams and troubleshooting procedures.
Check for technical service bulletins (TSBs):
There might be known issues with your vehicle model related to the U0401 code that can guide your diagnosis.
Me: try unplugging the multiplugs and using contact cleaner on them.
Postby metalworker0 » Sun Jan 26, 2025 8:17 pm
BTW - air bag light could be due to clock spring in the steering wheel .
This is a ribbon cable that is in the steering wheel that constantly un-coils and re-coils, so is subject to most wear .
search youtube with words
"CLOCK SPRING FORD CONNECT"
