Transit Connect 2023 D+ engine running signal
Postby KameTC » Tue Feb 18, 2025 10:05 pm
Hi, I have a 2023 Transit Connect 1.5 diesel automatic transmission.
Where can I get a signal that tells me the engine is running? Is there a wire that gives me 12V only when the engine is running?
KameTC
Re: Transit Connect 2023 D+ engine running signal
Postby KameTC » Mon Mar 03, 2025 6:15 pm
Please can anyone help me? In the Ford Transit there is a C33-E connector under the seat, where the engine on signal is present.
But is it the same on the Transit Connect?
KameTC
Postby metalworker0 » Mon Mar 03, 2025 6:28 pm
This any good to you ..may not be a connect ..but it is a transit .may be the same ?
https://moreysintransit.com/engine-on-s ... connector/
Postby KameTC » Tue Mar 04, 2025 8:24 pm
metalworker0 wrote:This any good to you ..may not be a connect ..but it is a transit .may be the same ?
That's what I found too, but I don't think it's the same as the Transit Connect
KameTC
Postby Chug » Tue Mar 04, 2025 10:24 pm
Get the Body Equipment Mounting Manual (BEMM) for your van and it will have info on the engine run signal.
https://www.fordpro.co.uk/en-gb/special ... lications/
Chug
