Ford Connect Ad Blue Error
Postby Weegaz » Thu Feb 27, 2025 8:08 pm
Hi Folks,
We have a 2019 Ford Connect with an ad blue malfunction.
It started with the warning 473 miles until no engine start.
Plugged in it gives error P208a and P208b. We have replaced the ad blue pump but still can not get rid of the error messages.
Any have any info to help with this one?
Many thanks
G
Weegaz
Re: Ford Connect Ad Blue Error
Postby metalworker0 » Thu Feb 27, 2025 8:38 pm
I found this service bulletin ,..it explains how to do diagnostics on your ad blue system ..its ford ranger ..but hope its very similar or the same it is a 2.0 ecoblue
https://www.tsbsearch.com/Ford/24-7040
Postby Weegaz » Thu Feb 27, 2025 10:03 pm
Thanks for the reply Mark,
Either I am being stupid or there isn’t an explanation on the attached link?
All I can read is the summary?
Weegaz
Postby metalworker0 » Thu Feb 27, 2025 10:38 pm
think i gave the wrong answer there ..was meant for another post i was thinking about ..the connect does not have a 2.0 ecoblue.
it may be of some use though ...as same faults
the rest loads up slowly ...it is missing for for a while until it loads !!!!
Postby metalworker0 » Thu Feb 27, 2025 10:39 pm
what engine does your connect have ?
Postby Weegaz » Thu Feb 27, 2025 10:48 pm
It’s a 1.5 diesel Mark
Weegaz
Postby metalworker0 » Thu Feb 27, 2025 11:00 pm
out of luck i'm afraid , very little info on the connects adblue set up.....and i have to search alternatives
all i can say is let that link up there fully load and hope that it gives some clues
Postby Frag » Thu Mar 13, 2025 10:11 pm
Have you still got those dtcs that will not clear ?
Or,have they now cleared and you’ve still got the ‘no start’ countdown ?
Frag
Ford Technician
