Nox sensor failure
Nox sensor failure
Postby yann500 » Sun Mar 02, 2025 2:43 am
Hi all,
I have P229E DTC on forscan, It seems there is a sensor 2 bank 1 failure.Where is on my ford connect 2019 v408 this sensor ? Thanks in advance '
yann500
Re: Nox sensor failure
Postby metalworker0 » Sun Mar 02, 2025 3:15 pm
Don't know, as you don't mention engine size
have a look here
This is a sub page of "catcar-info" site detailing all exhaust systems for all connects made after 2013
https://www.catcar.info/ford/?lang=en&l ... A9PTMwOTAz
main entry page for 2013 onwards connect
sometimes sensors are just called sensors on that site...youll have to sometimes put the part number into ebay to workout what type.
Postby yann500 » Sun Mar 02, 2025 7:51 pm
Thanks I will look at, my engine is 1.5l DV5 ecoblue.
yann500
Postby metalworker0 » Sun Mar 02, 2025 8:36 pm
Ford with their names lol .. naming everything ecoblue
going to put everyone off, as they will all (well me anyway lol) think "wet belt", which yours doesn't have
They confused everyone by naming a lot of other vehicles a few years ago as zetec, that be whether they were diesel or petrol or whatever, when the zetec name became the trim level and not the engine..
Postby metalworker0 » Sun Mar 02, 2025 8:53 pm
can you see a nox sensor there ..i cant ..maybe diagrams are not up to date?
Postby metalworker0 » Sun Mar 02, 2025 9:13 pm
from searches, think ford call it ..I could be very wrong
a nox temperature sensor
does that give you any more clues?
Postby metalworker0 » Sun Mar 02, 2025 9:31 pm
having probed all models in these forums here from google
there is no report of P229E here
i suggest use forscan
NOTE: and use forscan to get correct fault codes with proper explanation of them - your generic fault code reader may be somewhat misleading
Here on this site - They recommend "Forscan" which is FREE software that you download to a laptop..you buy the interface cable
You must join the forscan forum ..again free, to get the software and more answers.
https://forscan.org/forum/
Postby yann500 » Sun Mar 02, 2025 10:12 pm
Hi all,
I confirm that I use forscan and give me DTC P229E sensor 2 bank 1 failure. But I don't know where is it? Thanks
yann500
Postby metalworker0 » Mon Mar 03, 2025 5:23 pm
no ones answering -- all i can suggest using forscan you start dis-connecting and re-connecting sensors until you get a signal from "sensor 2 bank 1" that says its disconnected. think it may say something like circuit open.
Postby yann500 » Tue Mar 04, 2025 8:01 am
Hello,
Yes, it's a good idea but it's not easy to disconnect it, these sensors are placed in the body car. I will have to do it.
Thanks.
Yannick.
yann500
Postby yann500 » Sun Mar 09, 2025 6:11 pm
Hi all,
After disconnected each Nox sensor I found that is malfunctioning. I will try to clean it but I think to have replace it.
Thanks.
yann500
Postby metalworker0 » Sun Mar 09, 2025 7:03 pm
ok ... please tell everyone which one you found it to be ..2nd down from exhaust manifold etc ..just in case someone comes here and asks the same question .. :)
Postby yann500 » Mon Mar 17, 2025 11:36 am
Hello,
Yes of course, I will buy to replace it. I'm looking for the best price for this sensor. I will take and post some photos.
Regards.
yann500
Postby metalworker0 » Mon Mar 17, 2025 3:17 pm
make sure its got made somewhere in Europe on it, or Japan ..not China
Postby yann500 » Mon Jun 16, 2025 8:53 am
Sorry for the delay!!!
yann500
