Transit Connect PCV Valve 1.8 TDCi Location??
Postby 247Dealing » Mon Apr 07, 2025 4:55 pm
Hi guys. I have blueish / greyish smoke from my Connect MK1 1.8 TDCi. Rocker cover was leaking, fixed. Injector seals were leaking, fixed.
I still have light grey / blue smoke from exhaust. Not experiencing run away so suspect turbo seals are ok.
It COULD be leaking valve seals or piston rings BUT I want to try the PCV as the Dipstick is blowing out.
One problem is that I can not for the life of me fine the PCV valve. Oil separator is removed and is degreasing now.
Any help locating the PCV Valve please?
**2009 MK1 Ford Transit Connect 1.8 TDCi.
Thanks all :)
247Dealing
Re: Transit Connect PCV Valve 1.8 TDCi Location??
Postby metalworker0 » Mon Apr 07, 2025 5:13 pm
no pcv valve only oil separator
Note - there is this gizmo in the rocker cover ......not had the rocker cover off myself ..so just guessing
maybe it can get blocked ?
https://i.ebayimg.com/images/g/h7MAAOSw ... l1600.webp
Postby 247Dealing » Mon Apr 07, 2025 5:29 pm
metalworker0 wrote:no pcv valve only oil separator
Was guessing maybe no pcv. Thanks for that. Yeah I noticed a pcv looking plug in rocker cover. Will look into that.
Thanks, Mark.
247Dealing
Postby 247Dealing » Mon Apr 07, 2025 6:52 pm
I am guessing it may be an injector seal. I am getting blowby out the dipstick.
247Dealing
Postby metalworker0 » Mon Apr 07, 2025 7:40 pm
Think that only happens on the diesel engines that have injectors that pass through the rocker cover
