No fuel to injectors
Postby Johnb92 » Fri May 23, 2025 5:17 pm
Anyone got any tips for bleeding the fuel to injectors 64 plate connect and for the life of me I can not get fuel to the injectors tried with a squeeze pump got the filter filled I’ve tried putting the pump into the connection that feeds the injectors but after a couple of squeezes the pump stays sucked in so it can’t be pumped no more I’ve lost hope with it now
Johnb92
Re: No fuel to injectors
Postby metalworker0 » Fri May 23, 2025 5:34 pm
what engine
Postby Johnb92 » Fri May 23, 2025 5:38 pm
1.6 tdci
Johnb92
Postby metalworker0 » Fri May 23, 2025 6:22 pm
On that model you have as low pressure fuel pump in the tank
This is a combined device , this has a motor and pump, fuel screen and level sensor.
How to test
note these pumps can fail as jammed ...and can be un-jammed by hitting the tank with a plastic mallet ..but this is a sign that; that it is not long before it fails completely . also the filter screen can be blocked.
The in tank fuel pump gives 0.5 bar maximum, that's half a bar or 7psi
Think that would be ignition on ..engine ticking over or stopped.
When flat out ...well that's another set of parameters
But says in the specs: flow rate 145 litres per hour, So basically you'll be doing a test over 1 min which is 145 divided by 60
Which should return 2.41 litres a min, with i imagine an open pipe.
also look on this diagram to spot other devices such as one way valves and breathers to the tank that could stop the fuel getting to the high pressure pump.
http://www.catcar.info/ford/?lang=en&l= ... NisxMzM%3D
Postby Johnb92 » Fri May 23, 2025 6:40 pm
Thanks for the help it has just had an engine swap with one out of a focus I’ve changed everything over injectors fuel pump literally everything the van turns over great just no fuel at the top where it’s needed before I swapped the engine everything was working fine start first turn of the key was just pressurising turned out to be a cracked liner this is what baffles me as I know the pump and everything works fine
Johnb92
