transit connect 2013
Postby Yakka86 » Sun Jun 29, 2025 12:02 pm
Has anyone had any problems diesel return pipes as I have installed new pipes but one has started leaking again, i have used new clips as well, any ideas?
Yakka86
Diesel leak off pipes
Postby Yakka86 » Sun Jun 29, 2025 12:06 pm
I have installed new leak off pipes on my transit connect 2013, it was running fine for a week but is now leaking from another connector, i used new clips also, any ideas what i should do now?
Yakka86
Re: transit connect 2013
Postby metalworker0 » Sun Jun 29, 2025 8:34 pm
You need to tell people what engine you have in it, or people will not know what answer to give you .
what ever engine you have, i don't have the answer ..
so its up to someone who has had the same problem to answer this post
Postby metalworker0 » Sun Jun 29, 2025 8:51 pm
Until then, without the facts
, ... here is a different van and engine, maybe or probably the same set up though
You may find this discussion useful
viewtopic.php?f=2&t=233168&p=1870009&hilit=leak+pipes#p1870009
Basically saying you have some choices to make when replacing these ... whole assembly or just the o-rings or what ever you have bought.--- which didn't work.
