mk1 bulkhead on the steel floor or on the plywood
Postby metalworker0 » Thu Jul 31, 2025 8:08 pm
Mk1 bulkhead - on the steel floor or on the plywood
This is a genuine ford item ... does anyone know if it fits onto the wooden floor or the steel floor beneath it
if its fitted on the steel floor i may have to remove some of the wood
i just don't know at this stage .
also the rivnuts (captive nuts).. are these special that fit into hex holes or will just ordinary ones do... no rivnuts, as its never had a bulkhead .
Re: mk1 bulkhead on the steel floor or on the plywood
Postby dumper » Thu Jul 31, 2025 8:39 pm
I’ve had the rivnuts hex type from Ford in the past it was for a Ford option that we added it had the hex holes in the body .
Every Ford standard fitment bulkhead I’ve seen has always been fitted to the van floor the wooden ply lining had been a after market add on
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby metalworker0 » Fri Aug 01, 2025 6:10 pm
Ok thanks dumper -- i see the hexagon rivnuts on ebay ... but don't know if a special hexagon rivnut machine is required for them?
I have two pneumatic rivnut machines that i have never used .. picked up from car boot sales, no idea if they work, will have to get some practice in . ALSO friend has a manual rivnut tool that works
The wood floor stops 3-4 inches short of where the the steel floor ends.
There are rivnuts in place .. already ... but it does not seem enough and not spaced properly .. if it had a bulkhead in the past or maybe dog guard type. then it wasn't held by many and not held symmetrically .. then not all where used or they fell into the cavities when the bulkhead was taken out ..I just don't know
Postby dumper » Fri Aug 01, 2025 8:27 pm
I used the Blue point /Snapon one like a hand pop rivet gun just took it in small bites as they are stronger then the normal alloy ones .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby metalworker0 » Mon Aug 04, 2025 3:44 pm
Just an update
Well i looked on ebay and there was just not enough detail or was vague information on the sizes of the hexagon involved with these rivnuts .. information wasn't clear enough to get me to press the buy button, especially since it was mostly chinese sellers.
So looked at the net ... and it appeared only "screw fix" had ones that i could actually feel examine and try in the hexagon holes. so a trip to the next town and i had the set .
Only problem is i had to buy the whole Rivnut set to get the right ones.(of which there are 60 of 6mm in the set).. but they are definitely the right ones and I'm happy about that - £ 29.99 though!
https://www.screwfix.com/p/easyfix-bras ... -pcs/1380j
brass ? dont know .. they look like zinc plated steel to me .
Postby dumper » Tue Aug 05, 2025 5:19 am
Yes definitely zinc plated steel brass wouldn’t compress to clamp round the hole in the plate
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby metalworker0 » Wed Aug 06, 2025 5:44 pm
BULKHEAD FITTED - no snags - very easy 2 hours
Postby metalworker0 » Thu Aug 07, 2025 6:05 pm
Fist drive after bulkhead fitted .
van feels much quieter , less drumming of panels going on, less echo to the back of me , cannot hear the rear tyre noises any more, van feels stiffer, i think there is less flex happening.
Benefits
1. Was unhappy and felt in danger when carrying lots of loose items .. having them all crash into the rear seats when breaking hard. so now that is sorted. imagine carrying say 20 bags of rubble weighing 400 kgs , and getting into a head on collision.
2. Now will be easier to heat front cab, as reduced area.
3. The van is now stronger, so more protection in an accident especially from roll over.
4. Quieter , less drumming noises , less echo. less road noise.
5. People (thieves) cannot look through the front and see what's in the back.
Postby dumper » Thu Aug 07, 2025 8:43 pm
Yes Mark if you’re carrying loose items in the back you’re better off with the bulkhead many years ago had service one of the heating department vans took it out for a brake test slam the brakes on and a 3 1/2 kg gas bottle landing in the passenger foot well of luckily it wasn’t on the driver side
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
