Ford Transit Connect 2005 temperature
Postby Bisher » Sat Sep 13, 2025 11:19 am
Hi All
I bought a new Transit Connect in March.
The running temperature is about 100-109 degrees depending on journey.
Ever since I've had it, the radiator fan will stay on when I switch off the engine. There is also a bad smell like plastic burning.
There's no warnings on the dash.
Never had this with any other van I've owned unless sitting in traffic in hot weather.
Does anybody else have this with their van?
Many thanks
Bisher
Bisher
Re: Ford Transit Connect 2005 temperature
Postby metalworker0 » Sat Sep 13, 2025 2:42 pm
So there is definitely something wrong and how do you know the temperature its running at .
What's the dashboard gauge showing ..... if needle is strait up and in the middle its sort of 90 degrees.
The fan should not be on . generally they are overcooled when working properly.
i think you may need a new thermostat ...... NOTE : you buy the whole housing with the stat.
This is the first thing to do ... as for all i know, you may have a head gasket problem, so eliminate the thermostat as the problem first .
How my 1.8 tddi runs
Most of the winter the needle never travels beyond a third of the gauge, summer can sometimes be in the middle pointing strait-up on the hottest days - very rare.
and ive hope ive answered this correctly .. as you did say "new" is it 2005 or 2025 my answer is for 2005
Postby knobby1 » Sat Sep 13, 2025 9:15 pm
Bisher wrote:Hi All
Many thanks
Bisher
You mentioned you "bought a new Transit Connect", but the heading says 2005...is it new...or more than 20 years old..??
If it's new, it will still be under warranty.
Postby Bisher » Tue Sep 16, 2025 6:41 am
I’m a doughnut, yes 2025 model.
Has digital dash and shows coolant temp and oil.
Coolant is pretty steady at 90 and engine up to 109
Think I will get it back for a check.
Bisher
Postby metalworker0 » Tue Sep 16, 2025 3:46 pm
2025 - We are sorry, as we sort of cant help you .. as it's A VW CADDY badged as a ford, it's got a VolksWagon engine that we know nothing about.
Try the VW forums
I've no idea if the software we use on a laptop "forscan", meant for fords will plug into it or read it either.
and what knobby says .. if it's that new its still under warranty.
ALL THE BEST.MARK
Postby Bisher » Thu Sep 18, 2025 2:33 pm
Ok, thank you for the replies.
Bisher
