Transit connect stalling?
Postby Oldbutgold » Mon Oct 06, 2025 9:38 am
Hello. I have a 2011 transit connect 110 T200 trend. Most work is done by my local garage these days but even he is stumped. Occasionally at low revs the engine will just cut out, leave it ten minutes and it will start again. I did a journey on three separate days, and it cut out each time within 100mtr of each. Cam belt positon sensor and fuel sensor have been changed as per read out instruction, but nothing is shown with regard to cutting out, no history at all. Apart fron the three journeys mentioned the stalling seems quite random. Can anyone help please?
Oldbutgold
Re: Transit connect stalling?
Postby metalworker0 » Mon Oct 06, 2025 1:46 pm
My first check would be the EGR valve ... they can stick open randomly, if not regularly cleaned / serviced.
if not that, then you have to get forscan and observe live data
