2006 connect not starting no codes
Postby Chrispduck » Fri Oct 24, 2025 5:10 pm
Hi all I have a 2006 td which won't start straight away it's been in a garage thay said it was a fuel pump module 500 quid later still the same I have a snapon reader it shows no codes but when I clear codes it starts fine but if I leave it for a hour it won't start again until I clear codes again (which aren't there) here's where it gets realy weird if u turn it over about 8 to 10 attempts of about 10 revolutions per effort it will start to splutter into life only running on a couple of cylinders then about 4 more efforts it come to life!! Any ideas greatly appreciated and thank you in advance
Chrispduck
Re: 2006 connect not starting no codes
Postby metalworker0 » Fri Oct 24, 2025 6:00 pm
is it a tddi or a tdci .. and what codes are you getting.
Postby jay » Sat Oct 25, 2025 8:32 am
what are the codes?
Another thing to look at is the fuel filter has this recently been changed? if so check the seal is ok on the pipes it can be easy to damage the o rings
mk1 connect tourneo
jay
Postby Altransit » Sat Oct 25, 2025 10:04 am
As above, air leaking back into the fuel lines through leaking seals, causes the fuel lines, and even the filter, to empty overnight, and you're cranking over and over to refill them before it will fire up :idea:
Postby Chrispduck » Sat Oct 25, 2025 10:32 am
It don't show any codes I just clear
Chrispduck
Postby Chrispduck » Sat Oct 25, 2025 10:37 am
Sorry bit of a dumb ass how do I tell if it's a tddi or tdci
Chrispduck
Postby Altransit » Sat Oct 25, 2025 10:41 am
Chrispduck wrote:Sorry bit of a dumb ass how do I tell if it's a tddi or tdci
If it has electrical connectors on the injectors, it's a TDCi.
TDDi are purely mechanical injectors.
Postby Chrispduck » Sat Oct 25, 2025 6:20 pm
It's a tddi then sorry
Chrispduck
Postby Chrispduck » Sat Oct 25, 2025 6:27 pm
So today been playing tryed to start wouldn't start so accidentally left the ingnition for about ten minutes done nothing to the van tryed the key again and it went first turn!!
Chrispduck
Postby metalworker0 » Sun Oct 26, 2025 12:03 am
The only clue there is; by leaving it keyed on, you prevented some systems going to sleep or prevented the immobiliser activating.
Cant find info on here about resetting immobiliser ... but google says disconnect battery leave for 20 mins , OR.. then leave key in the on position for 15 mins .. which is what you did by accident .. and perhaps it fixed it.
Postby Chrispduck » Sun Oct 26, 2025 8:45 am
Thankyou everyone will keep tryin
Chrispduck
