Forscan Extended Licence Activation Problems
Postby pluggit » Wed Feb 04, 2026 9:24 pm
Downloaded and works fine on standard licence but i want to reconfigure some parameters(DRL lights).
I have been given an extended licence key but I cant get forscan to accept it. It says it can only accept a "binary" format. The key is a registry file format. Im confused.
Any advice appreciated.
Regards
Chris
pluggit
Re: Forscan Extended Licence Activation Problems
Postby metalworker0 » Thu Feb 05, 2026 3:53 pm
See that you got no response from the ford owners club also
so i found this
wondering if you wondered into the wrong section of forscan
so follow screen shot instructions here --- scroll
https://www.2gfusions.net/showthread.php?tid=4573
he goes on about binary and hexadecimal later on ... this is beyond my understanding and if you ask me , is only meant for computer geek people who have knowledge of programming or have studied at college level, computer science in depth etc .. why so complicated for a program that's supposed to be user friendly , i don't know.
if by reading that page .. you do get to understand it .. come back and explain, as it will help others he does say all your licencing is coming from Russia .. which is in a state of war .. which would also explain why the other Russian site catcar.info isn't working for me ... perhaps severs damaged blown up etc we don't know.
AND A SUGGESTION
if you have these codes pasted into Microsoft word ....... this is a wrong thing to do.. you should not do that, as it attaches all sorts of "html code" to the original code ... and unseen
use NOTEPAD ONLY
