Mk1 connect extreme shaking
Postby Chickendoink » Sun Feb 08, 2026 8:39 pm
Hi guys,
Picked up an other connect as a run about and straight away noticed that between 45-55mph in 4th and 5th gear the van feels like it is on square wheels. The shaking is extreme!
Other than that no shaking or vibrations.
Steering wheel doesn’t shake and clutch pedal doesn’t shake, am I looking at DMF failure?
New clutch going in this week anyway but any other issues I should check that could cause this while on the ramp?
Thanks.
Chickendoink
Re: Mk1 connect extreme shaking
Postby metalworker0 » Mon Feb 09, 2026 1:37 am
if talking mk1, Only Connects with a build date between 05/2002 & 08/2002 were fitted with DMF.
note build date not registration date
could be drive shafts
or flats on tyres,
distorted bulging tyres,
buckled rim
loose wheel nuts
engine mounts
these are what you want to check - all of them would be felt through steering wheel except maybe engine mounts
Postby g-man » Mon Feb 09, 2026 10:36 am
Had this problem, wheel out of balance
g-man
Postby Altransit » Mon Feb 09, 2026 11:23 am
If it was standing around before you bought it, you may have a tyre (or two) that has a 'flat' where it was standing, and more than likely, a rear one, if you can't feel anything through the steering wheel.
Try swapping front to back and see if anything changes, or swap in a spare :idea:
Postby Chickendoink » Mon Feb 09, 2026 6:42 pm
g-man wrote:Had this problem, wheel out of balance
As soon as I ease off throttle it stops the shaking without really lowering the speed which makes me think it isn’t tyre related
Chickendoink
Postby metalworker0 » Mon Feb 09, 2026 7:30 pm
whilst you are there
Alan howatt tells you how to check drive shafts here ..ford mondeo is similar and may be the same ..note how he turns the wheels to find the play
https://www.youtube.com/shorts/UV9E1JBBMZM
this is had to diagnose from an arm chair as could be so many things
all the best mark
Postby jay » Fri Mar 06, 2026 3:05 pm
another thing to check but as its a while since u posted check the gearbox mount the rubber can split
mk1 connect tourneo
jay
Postby bortaf » Tue Mar 10, 2026 9:51 pm
inner Cv joint, had the exact same issue on my mk1, if i stopped, put it on full lock and drover a few circles it would ease off for a while cos i hade a dry/worn spot in the inner CV.
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
