I have a SWB Connect, 2015, 1.6 TDCI with the 5 speed (MTX75?) gearbox.
I replaced the clutch a couple of weekends ago. I asked my local garage to do a diagnostic - one of the guys there is an ex ford-tech and told me clutch is gone but DMF sounds fine, so I replaced with a Valeo 3 piece. I've also replaced the hydraulic line that runs from firewall to the slave cylinder input.
When bleeding the clutch system, the clutch pedal springs to the floor with zero resistance, and then sticks there. Almost like it's gone beyond the point it's supposed to. I can hook it back up with my toe, and it springs up. I'm assuming this is due to air in the system, so I've tired bleeding and it's making no difference. I've tried the back-bleeding method mentioned elsewhere on this forum, but there's loads of brake fluid coming through the bleed screw threads for that to be effective, I think. Have tried gravity-bleeding (nothing) and just solo bleeding (with bleed pipe from slave cylinder submerged in fluid).
Have I buggered something up?
