NEW! Gen2 Performance Rear Lowering Springs
Postby LostinTransit » Sun Jul 19, 2026 12:50 pm
New Gen2 Performance rear lowering/leveling Coil Spring Kit.
Kit includes:
( 2 ) 20% stiffer & 2'' shorter rear Coil Springs for the 2019-2023 Transit Connect
( 2 ) Monroe Magnum 66608 (class 3) Truck Shocks
( 8 ) Custom Milled Heim Joint Spacers
Kit utilizes the factory M12 bolts and poly isolators. Total cost with shipping in US $1,200 (Shipping to UK will cost more due to customs fees)
Custom Powder coated springs extra. Wait time on the kit is 8-10 weeks
NOTE: This Kit has not been tester for the 2019-2023 UK Transit Connect.
This kits has not been tested on the earlier First Gen or Second Gen (non facelift) vans.
DO NOT run any other shocks with these springs.
LostinTransit
Re: NEW! Gen2 Performance Rear Lowering Springs
Postby LostinTransit » Mon Sep 28, 2026 7:42 pm
Edit:
NOTE: This Kit was designed for the 2019-2023 USA Transit Connect and has not been tested for the UK version.
Important: DO NOT run any other shocks with these springs as it will cause the springs to dislodge and fall out. On must use the 66608 (Class 3) truck shocks with this set up.
Sticker: https://www.stickermule.com/gen2performance
Instagram: https://www.instagram.com/gen2performance/
LostinTransit
